car has slow start, any advice?
KartFab
Dallas, TX
Hi all,
My car has been being a little weird lately. I do not suspect it to be a battery issue. What are your thoughts on this?
What I do know:
battery is good. Always reads good, is the max cranking amps/highest quality (i think its like a duramax gold or equivalent, a few months old, the kind that doesnt have the cells to look in and see water in it).
alternator is charging battery when I turn the car on and its idling, the volts at the battery are higher (i cant rememeber numbers).
car has a slow start sometimes Ok so basically, when I turn the keys it starts most of the time, it doesnt sit there cranking forever. Sometimes the car will do a slow crank for a revolution or two, then just stop cranking, i turn to off, and crank again, and its slow but still starts up. Seems like if I can get a revolution or 3 in the flywheel in there it just fires right up. I am also thinking (complete conjecture here) that running lights and ac on higher than normal somehow affects the cranking. If it doesnt start, i keep lights off, ac off, and it then starts. hmmmm
Anyway just wondering what your thoughts are here in the matter. I'm leaning towards that it could be the starter going out? Are the symptoms consistent with a starter going out? too big of a drain on battery? Wiring? What steps should i take short of paying someone else to check it out?
a weak connection,
a worn solenoid or
depending on the age of the car(or precisely the starter motor) worn out brushes.
sometimes it's just the bushing
(unfortunately yes.. most car starters run on bronze bushings instead of bearings :()
that either needs a drop of oil or is simply worn out completely ...
I'll start at the symptom (starter motor) check all that there is to check
(electrical connections, brushes if present.. need of lubrication... etc. basically everything that can be checked without pulling it apart.)
and then work my way back
solenoid (contactor), since it's already within reach and the rest of the electrical connections.
It shouldn't be far, the solenoid is on one terminal directly connected to the battery (well fused... but you know)
and one terminal should be nicely grounded to the chassis.
And if that's all good no kinked cable, no rusted terminal nothing that looks like a culprit,
then check your fuses pull em out, clean the terminals and put em back in or replace where necessary.
And if that's not helping I'm afraid you'll need to pull the starter motor apart maybe replace it :(
By your explanation I'd say it's a weak conenction, a busted cable a loose nut or alike.
So, make sure when you test the cable for resistance, that you bend it slightly to check for cracks, and if the insulation is corrupted, either replace or fix
(water can ruin the thickest of all copper in very short order)
Bbqjoe
Banned
Location, Location
Don't be so sure it isn't the battery.
A battery can show 12+volts. It can also show that it's accepting a charge.
That doesn't mean it has any cranking amps. It can still be dead.
Bwdeaton
Dayton, Ohio
Get the battery load tested at an auto parts store just to rule it out as a problem. Most parts stores will do it for free.
battery is actually easy to test... just ask someone to jump start your car..
when it's cting up on you .. if the starter runs nicely.. it's possibly the battery..
a car battery should read around 12.5-13V fully charged and read at least 14 when being charged by the alternator...
Anyways, as Joe said, even a dead battery can give you a good voltage reading at times.
if your battery sidewalls are bulged it's likely gassing out (yes that also happens to gel cells)
and lost some of it's power for example.
Anyways.. by your description [and age of the battery] and considering it's autumn already...
I'd say it's more likely a loose connection or broken wire.
KartFab
Dallas, TX
Wires were good. Took it to oreiley and they tested alternater, battery, and couldnt test starter because it wouldnt start. Starter was crapping out really bad. Bought a new starter
The fun things about hondas are that you have to take them apart to do the simplest thing. I had to remove the intake manifold itself, a bracket, hoses, fuel lines etc that were connected to intake manifold just to access the starter.
Was able to get the starter off and was putting a new one on. I had my wife helping me and she accidentally broke the knock sensor off while she was trying to move wires out of the way. Soooo FM... honda is going to be chilling in the garage for another two days while I wait for parts to be overnighted.
too bad about the knock sensor... but such things just happen in engine bays the size of a woman's purse.
Anyways, gives you time to pop open the old starter.. chances are it's just the brushes or the solenoid (normally the first things that'll fail)
both can be repaired rather cheaply (and the part can be put on a shelf or sold at fleabay...)
just saying ;)
Poboy kartman
Senior Moments Member
White Settlement Texas
It's not just Hondas...my Toyota pickup had over 10' of frame rail from tank to intake....where do they put the friggin fuel filter???? On the stinking block...where you gotta pull the friggin starter to get to?????
KartFab
Dallas, TX
well, new (rebuilt) starter (not Chinese crap) $200, OEM knock sensor and intake gasket overnighted $100. Added a little blood sweat and cursing to the mix, then new antifreeze and we are all set. (except for the cracked connection on the section of air hose between air filter and intake manifold, that's coming later. Before re assembling I put a thick straw on my shop vac to vacuum all the crap that fell into the intake during disassembly and then blew it out with compressed air. What a pain in the butt, but I'm good for another 150k miles on that starter now right? :wai:
