Anybody ever try retarding a stock camshaft by 1 Tooth?
I just counted 48 teeth on my Predator camshaft.
360 degrees / 48 Teeth = 7.5 degrees per Tooth.
Say you removed the governor, got a billet rod, upgraded the valve springs, advanced the ignition timing... You know, all the things needed to allow more RPMs.
I think Piston to Valve Clearance would be ok on a stock engine.
I wonder if it would run and what the powerband might look like?
Like if you could get 6k or 6500 out of a stock cam straight up, would you be able to get 7k or 7500 after retarding it 1 tooth?
Hmmm? Who wants to try it?
