Broke the starter recoil
D_CLARKE
Anyway i can get an electric start on a greyhound 6.5
Ive got two 12V Batteries strapped to the back PLEASE HELP Cannot get it started and i want an electric start:mad2:
anderkart
Surprise Arizona USA
Those electric start engines usually just have a red/+ battery cable that connects to your battery's positive/+ post. Then your battery's negative/- post needs a cable running to the karts frame or engine block.
If you've already done all this and it still wont crank, either your battery(s) are dead/defective, or there's a malfunction in your engines electric start circuit. You could use a 12-volt test light or any type of DC-volt meter to help diagnose the problem. You could also try connecting your karts battery to a known-good car battery with jumper cables. If it cranks fine like that, your karts batteries probably just need recharging or are defective.
D_CLARKE
It isnt an electric start its a pull start i just broke it the starter recoil so i cannot pull start it i was wondering if i can somehow get a starter installed on it so i dont have to pull start it ive got two 12V motorcycle battery's on it for the lights ive got hooked on it
You have two (simpler) choices. If you can find the electric start and charge kit (Ebay?), then buy it and install it. Or just fix your engine. A well tuned engine will start on 1 or 2 pulls, consistently.
Why did the recoil break?
D_CLARKE
The rope broke i took it apart and then it came uncoiled then we fixed it and then i guess it spun and chewed up all the plastic to the point where i cannot fix it what do i look for on ebay?
