briggs starting with governer removed
dduffett
How does the engine start if you remove the governer? Re I ask is if you direct connect the throttle linkage with a return spring doesn't that close the throttle plate and restrict any gas/air from entering the intake? I know you all remove the governers all the time and get them started but I just wanted to know if you hook up the throttle differently. Obviously the throttle plate is held wide open for a split second by the governer if it is connected properly. But I cant figure out how you get around this wilth governer removed. Plz explain if possible. thx
Aazza
I've just pulled the govener out of my gx140. All I plan to do is hook a linkage straight to the carb butterfly. The governer is just hooked up to the butterfly with springs anyway, so without it it needs to be adjusted manually. Same as any other engine that doesn't have a govener on it to start with.
That's what my plan for my engine is anyway. I'm no expert but I'm pretty sure I'm right....
Edit.. Woops misread ya. I think there's an idle adjustment on the carb to hold the butterfly open for starting. There tends to be on most carbs. But this is the first governor removal I've done so I'd be interested in the answer to this one too, provided I'm wrong.
Az
With the governor removed, the throttle then has to be connected directly to your gas pedal (or handle if you so choose). Many engines will still start just fine with the throttle closed, some require it open a bit. In those cases, you just hold the throttle open a bit by hand while you pull the starter.
DeathStarr89
Loose Nut
Davenport, Iowa
I usually just blow in the gas tank a little, i've removed governors on every flat head i've had and rarely had starting issues.
The cool bore that's on my mini chopper sometimes needs a little throttle to start but it's trashed. lol
Az
Great input but, unfortunately, a Honda throttle/governor setup is totally different to a B&S :oops:
