Briggs OHV intek vs blue clone
Devon95
Illinois, USA
Ive got a Briggs OHV 206cc intek and also a 6.5hp blue honda clone. They are rated at the same hp, but which engine should i build up? I plan on using a normal centrifugal clutch and a live axle.
Which motor would give me the best bang for my buck, and be easier to build up?
r_chez_08
Should be in the shop...
Cornwall, UK
IMO clone. There are tonnes of parts available (literally!) and they are relatively cheap. There is also loads of info out there about them.
Swabbster
id go with the honda clone, they have a cast iron sleeve witch makes them last a long time, not sure about the newer briggs but i know most of the older flatheads have aluminum bores
newrider3
Colorado
The Briggs Animal racing engine is based off of the 206cc Intek, so I believe that many Animal race parts will fit them. So there is just as good an aftermarket for the Intek as the Clone, the Briggs parts are probably a bit pricier though.
machinist@large
West Michigan, 49331
:confused: I'm not saying you're incorrect, but I was under the impression that Briggs & Stratton ran cast iron cylinder liners in their aluminum blocks; Nikasil bores and the like are awfully pricey for an engine thats going to be used on a lawn edger. Could one of our experts please clarify?:confused:
Devon95
Illinois, USA
The briggs i have has a cast iron sleeve, i can use either of them honestly. Im building one of em up to have a build off between my cousins and i. No rules on building it, just how much you can afford.
Ive found cams for the briggs but i dont know where to find other parts like rods, valves, carbs, and flywheels.
I do know that if i plan on using the briggs i NEED a cam because stock cams are some plastic pieces of garbage
slideways
If you really do have the I/C bore in your Intek you can use animal stuff. The head is different and is made for torque on the Intek. Which is actually good if you plan on being under 6000rpm.
IMO the clone is cheaper and easier to build. The Briggs will probably hold up better to 15+hp though.
r_chez_08
Cornwall, UK
Depends on the series. The I/C (industrial/commercial) engines have a cast sleeve. Some others are just aluminum.
:iagree:
They were known as kool bore engines, and ran different pistons and rings.
Devon95
Illinois, USA
Plan on a small dirt track, i know i wont exceed 6000 rpm, but if i do it will be very short bursts.
How big of a cam can i get for both before i have to start grinding to make room?
