Briggs and stratton Governor adjustment
untd103
Hi I own a manco dingo kart and untill recently it was extremely slow, about 15mph. I decided to adjust the 5hp briggs and strattons governor to increase the top rpm because it seemed to be only reaching perhaps 1500rpm. I loosened the arm and turned the governor screw anticlockwise untill it reached the more like 30mph which is what it should be capable of. The problem is the kart wont idle without engaging the clutch. The idle speed is too high and the kart moves as soon as the engine starts. I adjusted both the idle setting down to no effect as the throttle plate is half open. The clutch definately doesnt need adjusting. Any help is appreciated thanks!
sideways
Unfinished projects king.
Perth, Western Australia
A 5HP Briggs is meant to idle at 1750rpm so I doubt it was topping out at 1500rpm. Anyways, sounds like your having some problems with your linkages set up. What is stopping it from closing further than half throttle? If your going to mess with your governor then your better off just removing it, they have been known to break when submitted to higher than stock revs, then you get tons of little bits of plastic through you engine. Then you can hook your throttle cable directly up to the carb. Could you please post some pictures of your throttle and governor linkages?
Thanks
Hayden
