patthehat033
- Messages
- 77
- Reaction score
- 0
I have a 18HP Briggs and Stratton engine that was off a garden tractor. I am in the process of getting it fully running, (I need to order a rebuild kit for the fuel pump.) Anyways, I am putting this on a go kart.
The problem is, it is a vertical shaft engine. So what I am planning on doing, is either going the easy way out and trading it for a horizontal shaft if possible. Or I am going to buy a Right Angle Gearbox off ebay and then set it up like that.
But what I have a question about is the centrifugal clutch. I am pretty sure the drive on the engine is 1", and it is hard to find a cheap centrifugal clutch with a 1" drive. Do you think it would work, if I put the centrifugal clutch on the end of the Right Angle Gearbox instead?
So it would be -- The engine drive, then a chain would be attached to a sprocket on the vertical shaft on the RAGB, and then the centrifugal clutch would be on the horizontal drive of the RAGB, and then a chain going from the clutch to the sprocket on the go kart?
Is there a better set up I can do that is cheap? I do not have a job so spending a lot of money is not a great option for me.
