robbie
I'm in the planning stage on a bike with ATV tires. The rim is 10 inches wide, and the inside of the rim where you would put a drum brake is like a huge cavern 7.5 inches in diameter.
What kind of brake would you use on this kind of wheel? I could build the rear hub with three flanges, one for the sprocket, one for the rim, and one for the brake. I can do this because the hole in the center of the rim is 4.25 inches in diameter, so as long as the brake mounting flange is small enough to fit through the hole, I could pass that end through the hole during assembly.
With this in mind, should I just get a cheap drum brake from a go kart supply website? How about a disc? The ones I've seen for sale are all the kind that mount on a keyed shaft.
I think I have a good idea of how to build the hub, but I thought I should open it up for suggestions to see if you guys have any better ideas.
