How do you put a brake on a dead axle? Does it have to go directly to the wheel? What is easier a live or dead axle? I want to do a dead for pavement use but idk....
Yes the brake mounts right on the wheel which usually has a small drum on it.You can also use one of those brakes that press down on the tires or put a brake band around the clutch itself.
K that makes sense thanks, also i got a free (yay) BS intek 206, I am putting it back together but I have no idea how to hook up the throttle linkages (under the gas tank) if you have one you will understand, HELP!!!!
