Bought this today....need some help
My guess is the clutch spring is stretched or broken so, the contact shoes are not retracting; open up the clutch & check it out; the solution may even be simpler than that but, you/we won't know until you look inside
Remove the bolt from the end of the engine shaft &, if it hasn't been on there for 100 years, it should slide off. If it doesn't, first check for set screws in the rear of the clutch; if they're not used, get some PB Blaster in there...
It may be an idea to clean the shaft behind the clutch. You are in a unique position where you are able to slide the clutch backwards if you need to; having the shaft clean will assist in doing so...
