Boat transmission
Thedude
Washington State
Has anyone thought about using the gears from an outboard motor as a transmission so you have forward neutral and reverse? Tell me what you think about that
modelengineer
Lord of the noise
Sydney, Australia
I think it would be alright for a light kart, or if you use the gearbox from an outboard that had more power than you're putting through it. It would mean you could put the engine in a longitudinal configuration, which would be interesting. You could even have it front engined with a propshaft running down the side of the kart, since the outboard leg gives you a 90 degree drive.
