I would like to approach a thought, that will probably cause bombs to go off, just my thoughts.
pred 212's and other small motors can be hot rodded. We remove governers, stock exhaust, and intake modifications. We add cams, compression, rods, and flywheels all in an effort to pump up hp.... And sometimes "kaboom" because we "cross the line". The solution seems to be to restrict the rpm......a little bit. and yet to extract as much spin as possible short of "Kaboom"..
I have always taken a conservative approach... as follows my 212 has custom exhaust.....free flow intake... medium cam...18 lb valve springs.
I have removed the governer...the low oil sensor...stock throttle linkage......AND NO billett ROD OR FLYWHEEL. I have though retained the stock Carb with larger jet.
Now what I believed I have accomplished is......18 lb valve springs can float, ( therefore no over rev), The restricted carb cannot deliver enough flow to again "over rev".
So no need for expensive billett rod or flywheel ...voila And I fear no "Kaboom"
Again, I'm not racing or competing, I just want the strongest "FUN" motor I can have at a reasonable cost. Comment ?
Da Flash
Da Flash
