Bird Engineering Starbird
opsman64
North Carolina
I now have ten go kart 'frames'. Each purchase has been unique but most consisted of a frame plus anything the seller had that went with it ... with that being the model, I am accumulating a bunch of 'vintage' parts and pieces.
Disassembly, cleaning and repairing (where possible) parts that are 40-65 years old is HARD, frustrating and sometimes just plain impossible but I ALWAYS try to save everything I can ... most of this stuff is real steel and functional. I even took a welding class to learn how to weld new nuts on rounded bolts!
My latest find is a Bird Engineering Starbird. In my opinion this cart would have been purchased through a retailer as there was no Bird / Phoenix ID tag or holes for one.
As I disassembled, I found some cool and unusual things about a Bird Engineering built kart. Both axles are below the main frame rails as is the steering linkage. Additional bracing throughout. Steering shaft has a removable coupler at the top. The throttle and brake pedals are different although 'appear' to be factory? The rear axle stubs are crimped not welded and they are NOT threaded (grab that cotter pin)!
Obviously I never ridden it but I can't wait ... the dual scrub braking system is interesting as is the below deck steering.
PMW
Messenger_creation_06A09200-C2D8-4F04-9584-F9D1CF002A8E.jpegMessenger_creation_AC4F77AD-12E1-4A10-9C88-AACA78FE566F.jpegMessenger_creation_0FC6D35A-9943-464B-BFB8-5DF6D2D870B0.jpegMessenger_creation_AFC35146-8667-43C9-A771-EEF0D0D09BBF.jpegMessenger_creation_F550E6B7-F1F4-4383-A1FD-8CD226B787AD.jpegMessenger_creation_629DECC5-F12A-449F-92DB-3419155B7D4F.jpegIMG_20261119_132428.jpgMessenger_creation_083B6B30-D4D6-4C46-B96B-1F20F8165110.jpeg
Staff Murderator
My favorite bare bones, no frills kart. It is what it is. I think we determined that it’s a “pinch" friction-fit of the stub axles in the tube. Guess Bird developed a die to punch those out rapid-fire. Bird Engineering indeed.
I saw the pedal rubbers many years ago in the “oh crap, I need this” section of the auto parts stores. The aisle with the generic GM/Ford/Dodge parts that you needed to make your car functional again. The brake or clutch pedal rubber was an off-the-shelf existing automotive product. Have seen Bird karts with and without them in ads.
Cotter pins make it easy for the tool challenged or youngsters?
I now have ten go kart frames. You just saved me. I can now prove to my wife that I am not crazy by having four. And a mini bike. Thanks for all the help you have provided for me. Even if you didn't know it.
