bike gears?
hoobajoob
has anyone taken the transmission off of a mt. bike and used it as a finale drive? like this- engine to centrifugal clutch to sprocket welded on to one side of the shaft to derailer/bike gearing on other side to derailer/rear wheel gears? any tips on working this out would be really appreciated thanx
jrjulien1
nova scotia canada
we get questions like this all the time and the answer is no you cant use a bicycle gear system or chain on a go kart or minibike unless youre using a rediculously small engine like a 50cc or so because it snaps under a low power and a 141 or 135 chain {which is normally used on a minibike or kart} isnt flexible enough to be used on a bike style shifter so if you want to use some kind of shifting on your kart or minibike you can get a torque converter which will give you two gears or a two speed jackshaft found here
hope this helps
http://www.bmikarts.com/shop/?shop=1&cart=363655&cat=1&itemid=344&&thumbval=thumb
frank
anyone thinking of using a bike chain should first look at a #35 sprocket and chain, my reaction was "holy **** that's thick"
