Bigfoot engine and gearing questions
Speedfreak
I got a Bigfoot gokart and am ordering a new axle and trying to figure out the best gearing. It has new 18" IPT holeshot tires and with the current 5 HP motor that has a gear reduction on the side it had problems pulling itself with the wheels turned in the grass.
I am getting a new clutch and was going to run 12/72 gearing. But will a 5.5 hp honda turn these tires good enough to be fun and have a top speed about 30 or should I invest in one of those harbor freight 13 HP clones.
I am new to karts and don't really know how a 5.5hp motor will do with that size of tires and a live axle.
All opinions are welcome.
solomon
ca
The 5.5 is fine. With a 6:1 Gear ratio you should have an alright take off and top speed of around 25mph
Speedfreak
Thanks, I will look into the clone motor. I was also wanting to put an electric starter on this motor and the clone comes with one so that might be a deciding factor.
I have to buy a motor for the tiller so I might as well by one for the kart and use the 5.5 for the tiller. We'll see if I can find a good coupon for that clone motor.
Does anyone know of a video that shows the power that this motor gearing combo will have. I don't want it to pull wheelies but a donut in the gravel would be nice.
Speedfreak
I looked and I looked for a while but all I could find is the ones that have comet clutches like the yerf dogs.
Speedfreak
One more question. If I do go with Tue 13hp will a 35 chain be ok or should I upgrade to a bigger chain?
