Hello forum members,
I recently bought a Comet brand TAV-30 jackshaft plate
for an 93 cc engine bought on Ebay;tha problem with this,however,is that it will only mount without part inter
ference at a vertical position,i.e. in line with the engine block!!
This may work out if I could locate an spacer to raise the engine at a higher level than normally mounted on an engine mount,but I would like to know if the part(an exhaust muffler similar to the sardine can type found on most B&S/Tecumseh 3-6 H.P. L-heads) can be spaced about 1.5 - 2 inches without
having to make a custom jackshaft mount???
Thanks in advance for any replies!!
