OneTimeUser
We Don't Rent Pigs
First of all, I searched around and couldn't find much. The one promising link comes up 404, page not found.
Anyway, I want to keep the battery on my stage 420 predator charged and use some low-draw LED lights. It's mounted on a Murray Kilowatt an there is not much room for a stand alone alternator.
On another cart, pull start only, I solved the problem by installing a solar panel to keep the battery charged. It works well.
So, do I spring for an expensive higher-output alternator, or go with a solar panel to keep the battery topped off.
I do not have room for a stand alone alternator and I'm not planning on running the LED lights for extended periods-- just from time to time while I drive in the dark.
I await advice/experience from someone who has successfully solved this problem.
Thanks in advance.
Thanks in advance.
