Aaah, my first kart I built at age 14 with lawnmower parts had this exact type of clutch. It used a hand lever that could be engaged slowly for takeoff, and would "cam over" to stay locked in the engaged position once the kart was rolling.
One important design principle is this: The drive pulley MUST be of small diameter when using the belt as a clutch, otherwise it will be grabby to engage and won't disengage reliably even with the belt quite slack. Use one of the smallest pulleys available on the driver, and select a driven pulley 2 to 4X larger on the jackshaft. Larger diameter pulleys are an anti-slip advantage only when the belt is always taut, i.e. not used as the clutch.
There was a bar on the outside diameter of the belt, opposite the tensioner, that the belt would touch when it bowed out when slack, which stops the belt from moving.
That clutch taught me a LOT about how to gently engage a clutch on an engine determined to stall. So much, that when I started driving practice on a stickshift at 15, my dad wondered aloud if I had been sneaking the car out.
