Battery Charge Set Up
blanc12
Hey guy i whanna add a battery to my kart
i know u can charge them whit some sort of coil
i would like some help for the set up and where should i get the part from i new in karting and some vendor site would be apreciate
for sotk and race part
by the way i got gx200 honda engine loll .. .
thanks in advance
Blanc12 .. .
anderkart
Surprise Arizona USA
Did your GX200 come with an electric starter?
There's 3 different models of charging coils and flywheels made to fit your engine, (25, 50 or 88-watt)
The 25-watt charging coil has a max output of only 2.1 amp.
The 88-watt charging coil has a 6.6 amp output.
The system you choose depends on how much power you need. Will you be installing lights on your kart?
Here's some links to the different charge-coils and flywheels that are available:
http://www.ebay.com/itm/Honda-GX390...852?pt=LH_DefaultDomain_0&hash=item4aadc22d4c
http://www.ebay.com/itm/NEW-FLYWHEE...728?pt=LH_DefaultDomain_0&hash=item19cdd1bb98
http://www.nr-racing.com/stockparts.htm
Here's an electric start kit that includes a 25-watt charge coil:
http://www.ebay.com/itm/NEW-HONDA-G...392?pt=LH_DefaultDomain_0&hash=item4ab46ddf60
blanc12
thanks
can i use my stock flyweel whit the 88 one or i need tu buy another one ?
and the plan is to charge small batt and run a small pump and maybe a starter
thanks again
blanc12
anderkart
You'd need a special flywheel with extra magnets for any of the charging coil models.
The 88-watt needs a 4-magnet flywheel like nr-racing lists right underneath their 88-watt charge coil.
(1/4 of the way down this page: http://www.nr-racing.com/stockparts.htm
Plus the 88-watt system needs a regulator/rectifier like this one: http://www.boats.net/parts/detail/honda/H-31600-ZE2-861.html
You might find a lower price shopping around, but all the new parts I found for the 88-watt charging system were very exspencive. If you have a lawnmower shop in your town, they might have some good used parts at a more realistic price...
jrmints1415
Naperville Illinois
i just bought an engine with electric start does that mean it automatically has a charging coil?? because i cant find anything in the manuel about the electric start
You'd think so wouldn't you. I mean, to run the starter you need a battery & the battery needs to be charged.
I had the same question about my B&S 11hp, did some net research on electrics & found exactly what I was looking for.
anderkart
Yes it probably does. Depending on the model, an engine with a charge coil will have 1, 2 or 3 extra wires plus your kill switch wire.
