Back to Work
Meteshjj
Well, after a long winter of classes and a complete lack of money, I have finally decided to pick up my earlier project again. You can read my first question here: http://www.diygokarts.com/vb/showthread.php?p=248483#post248483
At any rate, I decided to shave the shaft. Now, it's down to a 1-inch shaft. The driven part that was on the kart is 6.75(ish) inch diameter, and a thickness when fully closed of 1 inch, measured on the outside. The Center Distance is 12-5/8 inches between the shaft of the engine and the driven clutch.
Now, here's my question; Will this work with a Comet 40 driver clutch like the one found here?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=360501605017&ssPageName=ADME:X:RTQ:US:1123
Is the driven from a Comet 40 series?
Meteshjj
I really don't know. It looks very similar to a Comet 40 driven clutch, but I'm not sure how to tell. The kart is homemade from the ground up, so I don't have much in the line of specs to go by. Where would I find a serial number or something like that to find out?
Meteshjj
The bungie cord is temporary to hold the battery in place.
One of the markings says "Richmond, Virginia." Upon closer inspection, I saw that there were two. The other one says, "Comet Industries."
... And now I feel kind of stupid. Anyway. I bought the Comet 40 clutch and a belt for it. I have to shave down the shaft a little more (Apparently, 1" doesn't mean 1"), but it's looking good. I will post some results (including pictures, zero to top-speed time, top speed, etc.) once I get it on the road again. Of course, I may have questions again before then. Thanks for the help!
Meteshjj
UPDATE: Everything worked! ... For about 10 feet. As soon as I put torque to the tires, my differential case snapped, locking the tires and sending bits of aluminum everywhere. Anyone know A good source for differentials? I know where to find car differentials, but not kart differentials.
Well there is this:
http://www.northerntool.com/shop/tools/product_35768_35768
I have no idea if it's any good for karts (especially for karts that size)
But it's the only small differential I know
I have a unit like that sitting in my garage; it came off a 11hp riding mower so, it should be able to handle a bit of torque.
The one thing I noticed about it is it's a bit flogged out where the axles leave the housing so, definitely a 4 bearing mount
Meteshjj
Is there any kart differential left?
I thought since the Comet diff isn't available anymore there are none.
Well there is this:
The casing for the differential broke, but the gears inside are fine. A bolt that was holding the two halves together sheared.
At any rate, I think I am just going to weld the stupid thing together and call it good. This is an off-road kart anyway, so I really don't need a differential. I might think about this one on my next build, though. I plan to go at the next one from the ground up myself so that I don't have to deal with other people's mistakes.
