b&s 900 series electrical question
joshkidner
West Michigan
i have a 2010 briggs 900 series (made for log splitters) modified to work on our gokart and its super fast and works great! BUT i am looking to hook up lights and i dont want to put a small battery in it and have to charge it everytime i want the lights. does anyone know how to wire up a battery? theres some wires going from the shutoff switch on the engine, to the toggle, to the low oil shutoff, and some other wires. theres a black and white one which i assume is going to something like a cdi? :mad2:
anderkart
Surprise Arizona USA
Those might just be your charging coil output wires. You could run the engine at 3600rpm and use a multimeter to check each of those wires for any voltage output. Test them for DC voltage and AC voltage because briggs made several different charging systems over the years. If your charge coil has AC voltage output you'll probably need a Briggs rectifier/regulator wired in to make it work.
You'll find lots more info in this Briggs download file: http://www4.briggsandstratton.com/miscpdfs/RNT/alternator_replacement.pdf
joshkidner
West Michigan
thanks, my neighbor is an electrician (he owns his own buisness) so ill ask him to borrow an ac/dc tester. hopefully its already dc so i dont need a rectifier :p
