Atc 200x won't start!!
To eliminate "too much fuel"-
Shut off the fuel and drain the carb. Dry out the spark plug. Now- pour about a teaspoon of fuel into the cylinder and reinstall the plug OR reinstall the plug and fire a 1-second burst of ether (starting spray) into the carb, and try to kick it over a few times. If this does not do it, fuelling is NOT your issue.
newrider3
Colorado
I had this issue on my DT175, appeared to be a nice hot spark but it still wasn't powerful enough to light it off. New coil and it fired up first kick.
dictionary6767
Nj
do you guys think i should get a new coil? i tried the no fuel in carb and starter fluid in it instead and still nothing.
FatCat
2 stroke Addict!
Ottawa, IL
I wouldn't quite yet. Wait till you get your throttle in place. Do you have any way of taking video and posting for us?
dictionary6767
Nj
Ill take a vid of it today and put it up here. The throttle should be here today ill let you know how it's works out.
