Arachnid build sprocket size?
cole thomas
Hello,
My son and I are almost finished with a spidercarts Arachnid. The engine is a GX390 with a comet 780 drive and driven clutch setup. There are 24" tall tires on it. The question I have is what size sprockets on the jack shaft and on the axle. It is meant for off road use with low end power in mind.
Thanks
Mark and Cole
The quick answer is the smallest sprocket you can find for the J/S & the largest you can find for the axle...
Even with a torque converter, due to the 24" tyres & the need for low end power, you will still need a final ratio around 8:1 or lower...
cole thomas
Comet 780 spacing
Does anyone know what the center to center spacing should be for the comet 780 clutch?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Here is what I found.
depends on belt size (O.C. for that matter)
and the driven in use
Driver:: 300821C (770-790 identical) OD 7.25"
DRIVEN:
790 SERIES (302603C): OD: 8.46"
780 SERIES (301789C): OD: 9.26"
770 SERIES (302604C): OD: 9.85"
Code:
PART #	ALT.PART # 	O.C. 	790 CD 	780 CD 	770 CD
704042 	300624 		34.85” 	8.16" 	N/A 	N/A
QDS136 	300780 		37.2” 	9.41" 	8.59” 	N/A
704043 	300625 		38.06” 	9.86” 	9.05” 	N/A
QDS137 	300634 		39.13” 	10.41” 	9.62” 	9.02”
QDS138 	300637 		41.22” 	11.5” 	10.73” 	10.15”
QDS139 	300638 		41.89” 	11.84” 	11.08” 	10.38”
704045 	300627 		42.22” 	12.01” 	11.25” 	10.55”
704096 	300663 		43.06” 	12.44” 	11.7” 	11.12”
QDS140 	300641 		44.14” 	13” 	12.25” 	11.56”
704097 	301086 		44.63” 	13.25” 	12.5” 	11.94”
704066 	300642 		45.69” 	13.79” 	13.05” 	12.5”
704098 	301195 		46” 	13.95” 	13.21” 	12.7”
N/A 	302663 		49.6” 	15.8” 	15.1” 	14.54”
QDS103 	N/A 		52.5” 	17.1” 	16.35” 	15.85”
CD: "CENTER DISTANCE" BETWEEN THE ENGINE CRANKSHAFT AND DRIVEN SHAFT
OC: "OUTSIDE CIRCUMFERENCE" IS THE MEASUREMENT AROUND THE BELT
