anyone used ampflow motors?
dcastillo
Tampa Florida, USA
I just realized the RPMs might be a bit to high... not sure I can correct it enough with the sprocket setup :(
seemed like a good deal to...
Where can I get a motor that higher then 1000W with out using a giant golfcart motor?
dcastillo
Tampa Florida, USA
Thanx, I have found lots of the 1000W models, but I am really looking for something a little bigger, closer to 1500W would be perfect for my cart. I am currently pushing about 800W now and its good to start with, especially for the kids, but I want to get a little more power for offroad riding...
thanx
Danny
That (original link) motor looks nice, but it has a very bad efficiency, at the top end it is less than 50% efficient, that is, it draws 1600W and provides just 700W to it's output shaft.
And on the top "speed" (rpm wise) of things, it is unable to provide any torque at all according to it'S spec sheet.
I'd say a nice engine for a RC application. but as soon as you apply weight and thus need torque it's going to drain your batteries faster than what you have ;)
the my1020 (thesciman's link) I don't need to say anything, that's in almost all electric scooters, most of kids e-quads and so forth.. Nothing fancy, good choice.
If you want to step up, I think you should think about a starter motor.
Say from a 3.0ltr TDI (12V and most likely around 1400-1600Watts), I know that'll require some tinkering with the controller, but it's cheap at ebay and nearly bulletproof.
You also will need to modify the motor itself a bit (diygk homepage provides a howto.)
Or use a truck starter (24V and almost every power from 2kW up to 12kW)
just see what you can find on ebay or CL for example.
In any case, check that you can find a controller for the voltage & amperage you need
before you actually buy anything, it doesn't help to buy a motor for $30 that you need a $900 controller for to run it ;)
dcastillo
Tampa Florida, USA
thanx...
right now I have a kelly controller that does 24-48V with continuous 80A, or 200A for 1min or so... so that should cover most of my bases...
sadly I dont have a lot of tinker time, especially with three kids...one of which is only 3months :)
So I have no problem spending a little extra cash if it means spending more time with the kids atm...
maybe I should stick with my plan of 2 1000W MY1020 motors (about $100 each), one for each wheel... I would assume that should increase my torque on the lowend enough for me...
thanx for the info
Oxymoron
Newbesque builder.
Maryland
Well... if you don't mind spending the extra cash... here's what I'm going to get for my little electric project (once I get it started, that is).
http://www.cloudelectric.com/product-p/pk-m909-axe4834.htm
Even though that's considered a starter kit, whatever you build out of it will have plenty of "testicular mass" to get you ROLLIN'. Yes. Large spheres below, indeed. :thumbsup:
Program the controller for the kids, then reprogram and max it all out when you're riding. Good times. That's my plan anyway... thought I'd share :cornut:
