advice on 8hp B&S...
Half-breeder
"Edit" button removed
I recently purchased an ole Carter off CList, which I got a GREAT deal on. I got a "live-axle"(incased...but a live none the less, upgrading a 'dead'), rear 16" rims, steering-wheel, tie-rods n ends, #40-#41, 60T and 12T sprocket, JShaft w/ mount, plus an assortment of metal framing(for other fabrications), and the main reason for this post... I got a 8hp B&S w/ no carb or exhaust(all for 90$ delivered). I can pull the cord n hear it has good compression...so Im guessing just gonna need a carb n pipe an exhaust.
This is "a" pic of the model motor I have...NOT the 'actual' motor I own...
My question is what is it that Im in need of, to get the motor running(nothing special). I know I need a carb...but does it have to be a specific carb or will pretty much any carb off 'any' 8hp work? I know theres the matter of jetting and air intake involved(im not mechanically inclinded... just know the 'basics'. Ive got friends for the technical stuff).
ANY advice as far as what to look for or even recommendations of useable parts will be appreciated.
Well, it'd be easier for us if you posted a pic of the actual engine but anyhoo...
Does yours have a gravity tank like the one pictured? If so, you can probably get away with any carb but, if it has a suction tank (sitting under the carb) you'll need the genuine article...
zbuck
Ft. Wayne, IN
:wai:Take your model number, type and code off the fan shroud and using those numbers go to Partstree.com for the correct carb. number and air cleaner ***'y number. Is the intake manifold and throttle control plate still on your engine? As for the exhaust, you can also find the stock muffler/exhaust system on partstree.com.
Half-breeder
It 'IS' just as the one pictured... N i was slightly mistaken, it DOES have an exhaust(i was half sleep when I looked at it evidently). I 'was' gonna keep the fuel tank/cell for my predator motor(cause it would SOOOO go w/ the theme for Lo-T)... but it's all rusted inside... Sigh... N GGGrrrrrrrrrrr!
Ill post a vid/pix tonite of it... Not at home atm.
Half-breeder
Heres my 'actual' motor...
zbuck
Ft. Wayne, IN
:wai: Good idea, Poboy kartman. That engine uses a up draft intake and carb, similar to the model T/A Ford design. If you are going to use a straight intake and carb., you have to remove that boxy muffler, because of clearance issues. Then you open up another can of worms, gov'n, throttle and choke control issues. Also with the fuel tank mounted on the engine your fuel outlet will be lower than your carb.
Poboy kartman
Senior Moments Member
White Settlement Texas
Definitely good advice. I prefer www.jackssmallengines.com/ because I can navigate it easier. Once there you can enter your model numbers and get an exploded view that will show the parts you need and the parts numbers. That way you will be able to recognize the parts and price shop.
