I suppose I should start off with a little back story. My friend had a go kart that sat in the garage for years. Awhile back (years and years ago) we decide to bust it out, setup a course, and try to beat each others times around said course. We got crazy with it and centered the steering wheel (making it a 1 seater but we kept the bench seat) and threw on what looks to be a TAV2 torque converter. BTW The engine is a B&S 5hp Fun Power. My friend ended up breaking the chain and lacked funding to fix it, so it sat, and we ended up forgetting about it after it got buried in the garage.
Fast forward 4 or 5 years. My friends parents wanted the go kart out of their garage and my friend offered it up to me. I had so much fun with it that I couldn't pass it up. It needed new oil, gas, and the throttle linkage was sketchy at best as it liked to stick open. Minor things to fix. So I started looking for the throttle linkage online and one thing lead to another. I ended up with a pile of go fast parts for it. Yes, I know, its a dual bushing aluminum block. I did my home work on it. I know it wont last forever and I didn't go horribly extreme on the parts. I just wanted something to mess around with and to have some fun with on occasion. Its one of my hobbies to throw money at stuff I have laying around even if its a lost cause.
Either way, I have a 94SS cam, new head, ARC billet fly wheel, ARC billet connecting rod, billet lifters, new exhaust and intake springs, air filter adapter, K&N filter, 3 stage exhaust & race muffler, a set of fly wheel key dealies, a complete felpro gasket set, and so many other small things that I really cant remember everything right now.
Now on to my questions. I've got the engine all stripped down and the only things left in it are the crank, cam, and valve train. This is more than likely a very stupid question especially since I could hit the search button. How in the heck do I get the valve springs, lifters, and valves out. I'm assuming I need a special tool.
Also, I regret it now, but funding did not allow me to just buy a raptor carb. So I bought the filter adapter and filter. Hind sight its 20/20 I guess. I highly doubt that my carb will provide enough fuel. The engine actually isn't the original engine. My friend burned the original one up and they ended up getting a new one. For some reason I remember seeing a date stamped some where on the engine saying 2001 was the manufacture date for something. Which makes sense because they replaced the engine 2001-2002ish. I don't know if there are any differences between older and newer fun power carbs. Either way, is there any hope for this carb? I remember reading that the jets might be cast into the carb. I haven't disassembled it to find out for sure. I have access to a machine shop and pretty much any tool to get what ever job I need done. Machining cast in jets is an option. Does any one know of any one doing such a thing if the jets are in fact cast into the carb? Also are there any other parts that might help the carb if machining is an option. I'm really hoping that I can change the jets or at least machine them as kid #2 will be here very shortly and money for a new carb just isn't in the budget.
This is really my first flat head engine build. I've got some pretty extensive experience working on Jeeps. I can tear down axles, trannys, suspension, t-cases, and the like, but this is the first time I've got this deep into a small engine.
Any way, thanks for reading my novel.
Not to mention I also need time to do some chassis mods, fix a few things on the chassis, and paint it (im thinking multicam). So I'm quickly running out of time.
