99 Polaris Sportsman
Pellethuntr2
Machinist
NY
hey guys so I have this project wheeler and I just got a new makuni for it and jump started it today... it ran great and all so I went to take it for a test spin and when I hooked up the cables again to jump it stupid me put them on backwords and now it has no power...so any ideas of what I did and what I need to fix??? thanks for any help guys
anderkart
Surprise Arizona USA
Hooking up jumper cables backwards usually results in blown fusible links and sometimes many other much more serious problems.
I checked your wiring diagram found here: http://www.scribd.com/doc/19783337/1999-Polaris-Sportsman-500-Wiring-Diagram and noticed it doesn't show any fusible links or fuses, but uses auto-reset type circuit breakers to protect the system in case of a short. You should check to see if power is still passing through your circuit breakers by testing them with a 12 volt test light or volt meter.
I also found some other info that might help here: http://forums.atvrideronline.com/70...9-polaris-sportsman-500-fuse-panel/index.html that claims some of your relays have re-set switches, so you might try to find those and see if they have a little button on the outside that you can press down to try resetting em.
