80cc dirtbike
element10554
Glen Mills Pa
Ok so I was on craigslist looking for an old dirtbike with an engine for my go kart and I came across an 80cc dirtbike that just needs a new piston ring. I talked the guy down to 150$. Now I am wondering if I should just fix the ring and keep the dirbike or convert it over to a go kart.
How much power does an 80cc have? I am about 6ft 160lbs. Alot of people tell me to go for the 125cc But I just want something to mess around with not go full fledged dirt biking. Is this bike to small for me.
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
Judging by the picture, it's definitely not a Honda. It looks like one of those Baja chinese clones, they were available at Pep Boys in the US and from Canadian Tire up here in Kanaduh. If it is in fact a Baja, it's also not an 80cc, it's more likely to be a 70 or a 90 (fwiw, size-wise it looks like a 70). I just went through a very similar experience with a Baja 50 that I bought for my son, it ran but made tons of blue smoke and had sparkly bits in the oil. I put a used Honda XR 50 cylinder on it (which bolted right up) and a new XR 50 piston kit, did the diesel-in-the-crankcase trick to flush out the badness, and now it runs like a brand new bike. If that bike is a 70 then Honda XR 70 parts will fit, but download the manual & compare the engine dimensions to make sure (OWNERS MANUAL - DR70 Dirt Bike Owners Manual US (VIN prefix LUAH). Good luck!
element10554
Glen Mills Pa
Since it is not a honda do you believe it is even worth 150$?
The Mechtician
Gargamel Jr.
Surrey, BC, Canada
$150 is a fair price. I paid about the same for my son's 50.
As far as how much power it will have, if my son's 50 will haul my fat *** around the yard then that 70 will probably go pretty good. Keep in mind it's a kid's bike and you're close to the weight limit for the suspension. It'll be fun for a while, but eventually you'll feel like a gorilla on a tricycle. Although at that point I guess you could scrap the rest of the bike and build a kart out of it :D
element10554
Glen Mills Pa
Oh ok I was just worried because my friends have said that they were on a 50cc before and it would not even move them. He is around 180lb so I wanted to make sure I could still ride it up hills and get around with it. Behind my house has a bunch of power lines so I ride under the power lines because its nothing but field although there is a few hills and rocks back there.
If worse comes to worse my girlfriend loves driving my go karts I can always upgrade to a 125cc and teach her to ride the dirtbike shes only 5ft 1 100lbs
