7 HP enough?
hunter schade
Hi all this is my first post to this site. I am thinking about building a go kart for the first time, and I am planning on using a 7HP engine, but I want to make sure that it will have enough power for me or my brother to use. I weigh 190 lbs and my brother weighs 235lbs, is this engine powerful enough and what gearing should I use?
FYI it would be a one seater.
DS13
Annoying the Neighbors!!!
Elysburg, PA
yeah 7hp would be enough with the right gearing. with that said how fast do ya wanna go? the answer to that question will help you figure out gearing. a common gear ratio you will hear around here is 6:1.
hunter schade
Thanks I'm not looking to go to fast, but I do want to zip around at decent speeds (20-25 mph). And where I live there its allot of woods/fields but not that many available parking lots to zip around (rural Maine). So it would have to be able to have slightly aggressive tire treads and a little torque.
DS13
Elysburg, PA
Do ya have the engine already? What brand is it? To have more torque your gearing would be 6:1 - 7:1 but should always be interchangeable if ya do wanna change it. There is a calculator on the home page of diygokarts.com if ya wanna figure out your ratio.
hunter schade
Hold up: You haven't said what type of kart you're building but, you did mention offroad conditions: Are you building a kart or mini buggy? With or without suspension?
Bigger tyres means lower gearing. Any hills means a CVT is preferred over a centrifugal clutch.
Can you give us more detail as to what you have in mind?
hunter schade
Sorry if I misled you, when I was talking about non pavement areas I meant maybe gravel pits or flat open fields, not hard core off roading. And yes I guess that a mini buggy would be more accurate than go kart. I have designed a suspension kit that would (in theory) allow me to adjust the amount of stiffness the suspension would have. So if I was in a parking lot, I could tighten it so that I could take corners faster, then if I went to a gravel pit I could loosen them to absorb any bumps there might be. I live in a very hilly area so I guess that the CVT would be better, but it would cost more than my engine. This is not supposed to be a serious kart/buggy but just something for me and my friends to mess around with. I was actually thinking something like this-
http://hpmoto.en.made-in-china.com/product/eoqmCbGUlSVO/China-Mini-Buggy-GK160B-.html
Not misleading, just not leading enough :)
There's a lot of grey area between "go kart" & "mini buggy"; some would say that's not a go kart because it has suspension, others would say it's not a buggy because it doesn't have a roll cage; you can see the confusion...
Something like that but scaled up wouldn't be that much of a challenge but, it may get expensive. However, once you scale up, it will be a bit heavier so, a 7hp engine may work but, don't rule out a big block honda or clone just yet
hunter schade
Not misleading, juwill leading enough :)
Theres lot of grey area between "go kart" & "mini buggy"; some would say that's not a go kart because it has suspension, others would say it's not a buggy because it doesn't have a roll cage; you can see the confusion...
Actually that looks to be the right scale but I will add a roll cage. I am kinda tall at 6ft but it is meant to be just a single seater, me and my friend actualy got our hands on a motor cycle engine a long time ago for free, but we were way over our heads back then. we gave up on making or own (neither of its knew how to weld) so we just bought a small one but it didn't really work for me because I was to tall and to heavy for it to work real well. But yeah I really just want to make a smallish single seater. I might ditch the suspension idea if that is going to add allot of difficulty/expense to it.
Just keep in mind that if you want to use an engine greater that 8HP, you will pribably have an output shaft of 1" diameter. Centrifugal clutches for 1" shafts are expensive, and if you decide to use a TC then you will need a 40 series Comet which is really expensive too
