600 cc motor?
a3ill
Hey guys im getting a Massimo 160 cc go kart for $500. Its only 3 yrs old. I would like to know how hard it would be to put a 600 cc bike motor in place of the 160? Would their be a ton of stuff to change to get this job done? Thanks for any input.
modelengineer
Lord of the noise
Sydney, Australia
Basically you'd have to reinforce the frame heavily, lengthen the kart, you should add hydraulic front and rear brakes, extend the throttle cable, add a clutch pedal and cable, make up the shifter linkage, and wire it up.
a3ill
its already a pretty big two seat go kart. I think you can get them with 400 cc motors on them. Maybe even bigger. It weighs about 450 to 500 pounds. I dont know a lot about go karts, but I figured it was built good enough for a 600 cc motor. Is it not?
modelengineer
Lord of the noise
Sydney, Australia
Well it depends on the motor. An industrial 400cc engine will make ~13hp whereas a 600cc motorbike engine can make upwards of 100hp. Which 600cc engine were you considering?
Swabbster
Just use a 440 sled motor or something, it would be fully automatic so anyone can drive it just gas and brake, over the last year I have accumulated 3 sled motors, two 440's and a 340 all air cooled, they mount with 4 bolts to something flat, there really easy to mount, there not hard to come across
fowler
Bullsbrook West Aus
what somthing like this
600cc is not going to be the the best idea
maybe 350cc if u are going with a bike engine
or as swabbster said a 440cc sled engine
but thats still quite alot of power
J_Walker
Florida
I wish I could find a sled engine down here, although I don't care for CVT, I like the idea of a light weight 2 smoke with big displacement.
I always see a lot of 600cc bike engines down here also. but I also see a lot of honda rebels. top speed is 70mph and they are about 16.1 hp, stupid easy to work with, normally pretty cheap bikes. but rarely are you gonna find JUST an engine. best bet is to buy untitled, but please - Run the VIN at the DMV first if you do this.. no need to chop up someones bike if they can get it back unharmed.
J_Walker
Florida
I searched for months for a rebel engine, or a 450-600c engine, and everyone wanted 1k+, I settled for an ATC for $50 and will put out roughly the same power as a rebel when I'm done with it.
Yeah, I know your pain, everyone in Florida think's their rusty POC is worth a kidney..
