6.5hp lawn boy
Drummining1monkey
I just came across this 6.5hp lawnboy on craigslist right by me. http://longisland.craigslist.org/grd/1828897381.html. How could with this motor be for a minibike? I have seen several on here on carts but haven't seen any on a mini-bike. Is the motor as large as a normal 4 stroke lawnmower engine is? $30 seems pretty good might even be able to get him to go a little lower if it would work on a mini bike well.
thanks for any help
-Matt
freakboy
the names 'mater
hick town
It would do great... just make a angled bracket for it and then make a intake to rotate the carburetor so the bowl faces down...
sideways
Unfinished projects king.
Perth, Western Australia
thanks for any help
-Matt
$30 is a pretty good price for one of them, you'l have to make mount to mount the engine in the correct position, the shaft needs machining or a shim to take a clutch and the carb will need to be rotated.
Russ2251 is the lawnboy expert on this forum, I'm sure he'll be happy to help you out. Do some searches on this forum, you'l find everything you need to know.
Thanks
Hayden
