6.5 Greayhound cam specs. at valves.
DrBob762
hello all im new here and need some tec. info if available. I have a 6.5 greayhound engine driving a 2.5 KW PE-75 belt driven generator head. the system works pretty well as is but being an old gear head im always looking to "IMPROVE" things. I am looking for the cam specs (at the valves) so i can calculate the optimum pipe length and diameter for a specific RPM to achive the most torque at that point. Since this is a stationary set up and running at a steady RPM this is much easier than designing one for a cart or bike that must preform over a wide range. I have the equipment and expertise to make the measurements for myself, but thought maby someone had done this allready and might be willing to share the info. If so I could use the opening and closing degrees(BTDC & ABDC) of the intake and exhaust valves. The total lift of each and the valve overlap between them. With this info it is possible to place it in the appropate program and arrive at the calculated optimum pipe diameter and length for a given RPM. Sounds like a lot and it probably is, but i thought i would ask first before re-inventing the wheel so to speak. any help with this project will be greatly appricated. But if I end up doing it myself I'll come back and post my findings. Thanks in advance, DrBob762.
