6.5 clone. what next?
mpepin48
I recently purchased a box stock engine kit from ARC Racing. It came with a .615 bored carb, high tension valve springs, BSP-2 cam, and I also purchasd a billet flywheel. I have it all assembled and have ran it for a few minutes. I am still wanting to get a few more HPs out of it, and am wondering what to upgrade next. Willing to spend about $200 on it. Any advice is appreciated :)
http://m1291.photobucket.com/albumview/albums/mpepin07/Mobile%20Uploads/20130610_211207_zps84a8e53c.jpg.html?newest=1
Only things I can think of right now are
-billet rod (if you haven't already, you didn't comment)
-flat top piston &/or thinner head gasket
-head work (shave, port & polish) if not already done
There's not really any other parts you can add, it's now more about what parts you can improve
You can also increase the compression ratio by installing a small-chamber GX160 cylinder head. Then, you can advance the timing a few degrees, and run high-test gas.
