6.5 clone throttle linkage question
Mikeythai
I've searched the forum and seen some great ideas for hooking up throttle cables. But I don't understand how the linkage from the governor arm is set up. Here's what I have now-- before I put any cable on.
Maybe something's not hooked up right. When the governor arm moves to the left the rod opens up the butterfly in the carb. But shouldn't there be a return spring to close the butterfly?
I'm gonna keep the governor because this kart will be for my young son, but I just want to know how this should look/work.
the-cyborg
Spring, Texas
In that pic your governor arm is the one to the right, if your not going to remove the governor gear inside the engine then leave this arm alone.
the arm to the right is the is the throttle arm
in the picture below at one of the two red circles you'll need 1 of these ---> http://www.mfgsupply.com/m/c/AZ2361.html?id=PdJBnMUB
And a cable stop to hold the cable, something like this goes where the green is ----> http://www.mfgsupply.com/m/c/AZ2380.html?id=PdJBnMUB
Go to Home depot and in the hardware section they have a small assortment package of springs of various lengths and stiffness.. ( You don't need very stiff springs)
Return springs goes where the yellow is.
Now you may or may not need to drill small holes to hook up return springs and you may have to loosen the nut that holds the throttle arm just a little until it moves freely and easily.
Blue is a throttle speed adjustment, can be used as a speed limiter ... I use to use this on my kids carts when they were younger to further limit their cart speeds.
I hope this helps, seems like 10 times a week someone ask about honda or clone throttle hookup, guys its not rocket science, just common sense.
Mikeythai
I get what you're saying on how to hook up the cable and the springs, and it looks like a great way to do it. This is more like a problem I'm seeing before I even design the throttle cable setup.
The throttle arm is only connected to the governor arm with a flimsy spring. That spring has too much give to push the governor arm all the way over. And the butterfly never closes to it's stop.
I loosened the nut on the throttle arm and same result.
I google searched this 50 different ways and found a couple of guys that added a small return spring on the right side of the governor.
Long story short... most guys take off the governor first thing and never run into this problem.
r97
Measure twice cut once
Massachusetts, USA
keep the governor on, don't wear down the engine more than you need to.
leave the governor as it is, it is setup correctly. the reason for a spring instead of a solid rod between throttle arm and governor arm is because having a solid arm would allow the throttle lever to move the butterfly directly, eliminating the function of the governor.
the governor arm will automatically close the butterfly valve as soon as the engine is started.
kendelrk
redneck engineer
westland michigan
i noticed it does do that, but for the sake of the engine i took a spring i got in a spring box, from harbor freight and hooked it directly to the governor arm, and pulled it back to the recoil, because i didnt like how easily the governor got pushed, once the spring was hooked up i felt it had a better pull to it
r97
Massachusetts, USA
the way i'm understanding this, you have either limited the engines maximum RPM below 3600RPM, or increased the maximum RPM.
the-cyborg
Spring, Texas
with the engine running the centrifuge force on the governor gear/weight assembly in the engine will excerpt pressure on the governor arm that will overcome a certain percentage of the spring tension allowing the engine to run at no more than design maximum engine rpm's
Mikeythai
Oh. Yeah I understand what you guys are talking about. I spent many hours today trying to understand the design of that thing. The governor opening at idle RPM's didn't occur to me.
Makes perfect sense, thanks for posting.
dono
Zephyrhills, Fl
hello, im new here and i see alot of good info.
i bought a 6.5 hp from harbor frt i need to know what kind of throttle cable to use and how it connects to the engine. thanks
Dono- you really should start your own thread. Meantime, bicycle brake cable, and read our thread called "Helpful Links From The Forum" in the FAQ section for throttle connection info.
