6.5 clone idle issue
ivickers
NSW, Australia
Hello all, what a great site for useful information.
I have a new honda clone 6.5 that wont idle it will start on choke and run for a few seconds after turning the chock to half or fully off. As the engine speed dips the governer opens the throtle, it then dies.
If I move the choke back on as the engine dies it will keep going.
I have thoroughly cleaned the carb, I wonder if the governer setting could be out.
Any clues are much appreciated.
Ian.
ivickers
NSW, Australia
thanks Peterbilt, I have a carb that has a idle mixture screw and idle adjustment screw, i have tried to moving the mixture screw from all the way in to almost dropping out .5 a turn at a time. I believe i have the idle speed okay as it will idle for a second at a good speed. I have adjust this also however.
ivickers
NSW, Australia
Hey fellas, i have found the problem, there was a very fine hairline crack in the bakerlite insulator block between the carb and head. New block and zooooom its a goer.
thanks for your thoughts.
#15 - INSULATOR, CARBURETOR (Honda part# 4743068)
