5hp briggs running help
gokartski
i just got a gokart up north and it has a 5hp briggs flat head, well being the guy i am i knocked the head off and cut down the eye brows, pulled out the governor, and am running no head gasket. well now no matter what i do with the air screw, i cannot get it to run right. it will idle very nicely but when i hit the throttle it bogs and dies. im into quads and stuff and am not a stranger to carbs my question is am i suppose to rejett, :mad::mad::mad:or is there another issue?
DeathStarr89
Loose Nut
Davenport, Iowa
Unless you have the head and deck surfaces perfectly machined flat then you need to run a head gasket. You can get thin ones but at least put something in there.
If it ran fine before, that's likely your issue. you can confirm with a compression tester.
good luck!
fowler
Bullsbrook West Aus
I assume u cleaned the carb at some point
Is there a chance of contamination during reassembly
Did u do anything else like hi flow air filter
But not running a head gasket is likely the issue
