Now here's a question, My neighbor is only going to transfer my parts over to his block if the scratches are too bad, so if it is a cast iron sleeve, will my kool Bore parts be compatible? I will be swapping the con rod to an arc 3.875". Where can I get a good non-oversized aftermarket piston? Flywheels are $200 which is out of my budget, what are my chances of it exploding?
