Hi everyone, I'm working with my brothers on our first go kart project but I've run into a problem. I've got a 5hp briggs and stratton, but the crankshaft is tapered and I don't know what size clutch to use.
It has a keyway at the end while it is 7/8" diameter and then closer to the motor it steps up to 1" diameter. I can't even find a 7/8" bore clutch and the 1" ones are pretty expensive. Does anyone else have an engine like this? If it helps it came off of a chipper/shredder.
Thanks in advance.
Thanks in advance.
