50 cc on power wheel
dvav340
So I built a frame for my kids power wheel and installed a 50 cc from a pocket bike . The problem is my gearing it has 6 tooth on the motor and 80 on the axle .the tires are 15 or 16 inch tall. The 80 tooth was the biggest i could find and it is not enough.has anyone used one of these motors successfully on any thing like this . I have ordered the same motor that comes with a gear reduction box but I do not know the gear ratio of it
dvav340
I think I probably could but I am not really sure what the gearing should be
pocketbiks... that's #25 chain, is it not?
then there's a 90T sprocket as well. which would lower your ratio to 15:1
https://www.electricscooterparts.com/sprockets25chain-wheel.html
would still be very tough to move with wheels of that size I'm afraid.
I don't know what weight you need to move around nor what power that engine is able to provide (at which rpms)
sooo it's nothing but guesswork, might be just enough *shrugs*.
Well then .. *sigh*
That setup is rather bad tbh..
a six tooth sprocket on the engine, if you're very lucks 2teeth are engaged at all times..
those take ALL the load and torque..
IF you get the vehicle to move, you'll run through chains and sprockets like crazy.
especially on flimsy chains like #25...
And while a pocketbike can take such setup even with an adult
it's in fact a matter of driven wheelsize (since it's the torque that chews the teeth down)
and that's the main reason why pocketbikes come with such tiny little wheels ;)
Oh btw you sure it's a 50cc?
most common chinese pocketbikes look all alike, and some come with only 32-33cc
and the engines look exactly the same at first and even second glance
Good luck, but I guess you will not get it to work reliably without installing a jackshaft to compound the gearing and larger sprockets all around :(
dvav340
I finally got it running thanks for the input I would post a video but I can't seem to find out how
Ebrownie
Western Montana
You cant post a video directly onto the forum like a picture. You have to use a 3rd party website like photobucket or youtube and then post a link to the video.
