5.5hp engine Help
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
Hey guys i just bought a minibike with a 5.5hp clone engine. I can get it to run on starting fluid but after that runs out (like 1 or 2 seconds) and then dies. It has a full tank of gas, and i just changed the oil and the spark plug. But it still wont stay running...... Any ideas?:toetap05:
machinist@large
West Michigan, 49331
It's not getting fuel; probably a plugged up carb, line, or petcock.
j.concepcion54321
East Providence RI
ok, the petcock is good because when i took off the line it started pouring out gas...
the line is good because when i removed it from the carb, it also dripped...
So i guess it must be the carb..... :mad: I loathe working on carbs....
the-cyborg
Spring, Texas
Pull the carb, take it completely apart and thoroughly clean it.
I pearsonlly use Berryman Chem-Dip Carburetor and Parts Cleaner you can get it at at most any auto supply store, comes in a gallon can like paint, and has a nice little basket to soak your parts in. follow up by spraying every thing inside and out, every crevices and orifice with carb cleaner, run a wire into every crevices and orifice to insure everything is clean, then thoroughly blow everything out with an air compressor.
Also drain and clean out the tank.
BTW you could also boil/soak everything in lemon juice, it works, but IMO stinks to high h3ll, and doesn't really do much for the brass jets and whatnot.
j.concepcion54321
East Providence RI
ok so i took off the carb but before i started cleaning it i noticed that there was like a hole near the top. i looked at my other carbs and most of them have little screws in that hole so i thought that might be my problem i attached some pics of what im talking about... can someone tell me if that should be like that or if something goes there.. if so what?
kendelrk
redneck engineer
westland michigan
thats your idle jet, the screw your referring to goes in the hole to the side of the butterfly and thats your idle screw
kendelrk
redneck engineer
westland michigan
make sure the idle isint to high, or to low, make sure the idle jet is pushed in, take off the bowl, and turn on the fuel, if it drips, its somthing else
the-cyborg
Spring, Texas
Do yourself a favor get a 22 MIKUNI round slide with 1.3 mm main jet and a intake manifold from NR racing, you want regret it.
Those clone carbs are crap suck big time, I had nothing but problems with them, poor idle, starving, flooding you name it.
After the first mikuni I installed, all my projects get them now, even my Subaru EH41 13.5 now has a 34mm Flat slide.
I'll even bet you'll find some get up and go you didn't know you had. :D
the-cyborg
Spring, Texas
can you show us some more of the throttle setup ?
All you have to is file down the lead ball on the cable to fit the slot in the slide, or do like I do and make yourself a lead mold buy drilling a hole in a piece of 2x4 slightly larger than the diameter of your cable and about 1/4" deep, melt down some old lead fishing weights or old wheel weights, center the cable in the hole, and pour a little molting lead in it, let it cool wala instant cable.
Maybe I'll make a series video howto's on slide carbs
j.concepcion54321
East Providence RI
That mikuni carb is too expensive for me.
I found the following stuff at gxparts.com
Gas Cap........2.99
Carburetor Assembley.......17.99
Air cleaner assembley.........11.99
Shipping...... 15.30
Total...... 48.27
Is that a good deal? or should i keep looking?
