5.5 hp briggs and straton intek
vgk
Las Vegas, Nevada
My intek is geting hard to pull the pull rope. The firsh thing I thought of was the clutch, so I took off the chain but it is still hard to pull. Any sugestions?
Thank you
Vgk
vgk
Las Vegas, Nevada
When I pull it it will pull the rope out some and then jerk my arm and just stop. I can pull harder and it will go but it keeps on doing this
Thanks
Vgk
solomon
ca
Sounds like you have sheared the flywheel key. Try starting it on compression stroke, pull the rope slowly until it gets to the hardest point, let the rope go back in, then pull it very hard. I would check the key though if this is something new.
Blazkowiez
Kart Aficionado
Houston, Texas
My thoughts might be something cause your valved to go out of adjustment. Check your valve lash at top dead center. Have you altered your valves recently?
solomon
ca
check the valve clearance first since that is so easy, then Pull the flywheel and check the key, both procedures together should take no more than 45 minutes.
vgk
Las Vegas, Nevada
Ok I will
not today, its nasty out
It is hard to pull but when I pull hard enough and it starts, It runs perfectly normal.
