cameron.luster@yahoo.com
I need help trying to figure out how to hook up the charging on my predator 420. It has a single wire and when i check it with a meter it’s reads it as a ground with the engine off and with it running it doesn’t read as a ground. I tried hooking to the battery but it sparks so I didn’t do it. I know the wire is coming from the charging coil but have no idea what to do to hook it up to charge my battery. I have this 420 on a carter talon and have already ran wires to use the electric start. I’m not using the switch that came with it. Everything is hooked up correctly and works fine besides the charging side. I have no idea what to do. Picture should be attached.
