#40 chain on a 420 sprocket?
XS86
#40chain on a 420 rear sprocket? Will it work fine?
Also another question I have a 16 hp engine 21lb of torque with a torque converter sprocket on the torque converter has 10 teeth. I want to mainly do trail riding and going through mud. How many teeth on the rear sprocket do you recommend and why?
Bbqjoe
Banned
Location, Location
Anything above 60.
Why?
'Cause I said so.:cool:
PredatorPowaaa!!
Mistake Maker
Ontario,Canada
You didn't even mention the tire size which matters in the ratio. I have a dune buggy with a PA 208cc with a few mods on it. Trans is a 30 series tourque converter and the 10 tooth 41 sprocket. Tires are 22" tires, but they are probably around 23"-24". Rear sprocket is a 60 tooth. It is plenty tourquey and will do 70 kp/h on a flatish gravel road. I feel like it wouldn't be a bad idea to go up to 65 tooth or maybe even 70 to prolong the life of belts and put less stress on the TC. Unfortunately due to the circumstances of my frame (a sprocket bigger than 60 tooth would hit a part of the frame) so I plan to get an 8 tooth gear for the TC. Overall, its fine on very steep inclines and hilly trails, but I feel like it could use a tad more tourque. So yeah, if you can do 65t or 70, do it.
