33cc 2 Stroke Scooter Engine
Canada, AB, Spruce Grove
Anyone know of a way to generate electricity with this motor so I could power an electrical system? I'd rather have it built in than use a battery. Like something that could just be attached with a chain, or something, in order generate some power.
Anyone know if it would be possible to put a small alternator (Anything you think would work) on here that could still somewhat charge a 12V battery?
Well I looked for awhile and didn't find anything. Maybe I'll just get lights that rely on the wheels turning to power themselves.
Ordered my gaskets yesterday. I would've done it sooner but Paypal was being dumb. They should arrive late next week or early the week after.
solomon
ca
A Walbro Carburetor helps ALOT on those engines. Throttle Response is much "Snappier"
This carburetor, I think, is actually a clone of a Walbro carburetor. I'm not sure which one though but I could probably find out. Could you explain further as what you mean by snappier? Do you mean more responsive?
My gaskets are so close but so far :auto:
Gaskets came in today :thumbsup:
So now I have the tank, fuel lines, gas, oil, and gaskets. Sounds like I'm set. I still need the primer bulb so I'm going to get that on Thursday or Saturday. Hopefully it'll start and run nice.
Okay so I've been real lazy
I've gotten even lazier :oops:
However I put everything back together. I had to make my own gaskets for the one missing and didn't want to pay for. I think it went okay. Now I have a new issue. The engine likes to stall without the choke on. I can hardly even idle without the choke and doesn't last long with the throttle going on no choke. Before this video was filmed, I had the engine running (With constant stalls) for maybe 30 minutes, so by no means was it cold. I think something is wrong with the carb. Should I take it apart and put it back together again?
http://www.youtube.com/watch?v=XHhQrajHqho&feature=youtu.be
My dad suggested to spray gumout in the carb and feather it while it's idling to remove the, "sh!t," that's in the engine after so long. Opinions?
He's a wise man, your dad; there's probably some gunk stuck in the carb somewhere...
It could also be (but not exclusively) the mixture settings; those engines have high & low mixture screws; the trick is to set the low mixture, then adjust the high at WOT; once adjusted (after cleaning, of course), it should snap open & rev out quickly; if it doesn't, your high mixture is off...
Mixture screws? The only screws I've seen on this carb are the idle screw and rich/lean screw. Are you talking about the screw that adjusts the richness and leanness?
Ah so I just rewatched this video and the 1st and 3rd screw should be the ones I'm looking for. Is there any way you could re-explain what you said earlier in reference with this video? I'm having a hard time grasping it.
MY FATHER AND I GOT IT WORKING
We spent at least 3 hours today trying to get it to start. We'd do things like take the spark plug out, putting some fuel in the chamber, putting the spark plug back on and starting it. We also put the spark plug under a lighter's flame to get it hot so it'd start easier. We tried it with choke both on and off. We had it start once, and it ripped real good, but stalled after maybe 20 seconds. After that, it wouldn't start again. Keep in mind I'M the one who has been pull starting this thing the whole time and a couple hours yesterday. I have one nasty blister on my right hand a small one on my left hand. They sting so bad. Now here's how we got it to work. We decided to rebuild the carb, the first time my dad wanted to do it his way with the gaskets we had but we had ALL the same issues as before. Then we rebuilt again, after we both watched this video we rebuilt it correctly. When I had first rebuilt it, I made some rookie mistakes and did a few things wrong. Once we correctly put it back together it fired up first pull :wai::wai::wai::wai: I could feel all the sweet relief in my hands. I was even able to ride it for awhile! I'll get you guys a video later :popcorn: (Probably not until Monday because I'm going camping for four days). It's nothing too fancy to brag about, but I'm just ecstatic that my first motorized ride is working again.
