3 HP Predator flywheel?
Logan County Ohio
I see listed in some catalogs, a "3 HP predator flywheel" not much info is given. Is this something that can be used on the 6.5 engine to spool up quicker? If so, one would need to move the coil closer. I don't know if the shaft size or taper is the same. I didn't know that predator even built a 3HP. Just wondering if any of you knew about this.
Gokartbill
Atwater,Ca
Predator engines from harbor freight does make a 79cc 3hp engine but unfortunately the shaft is a 5/8. Smaller than the 3/4 shaft of a 6.5. You can either fork out 70 bucks for a pvl racing flywheel or find a genuine Honda 6.5 flywheel which I believe are a little lighter than the cast clone flywheels.
the Honda flywheel does not fit new predators!
(I can't remember the year when the predators got a different taper)
So before you buy a honda or clone flywheel..
get an ARC flywheel MADE FOR (your) predator :D
But if I understand the post correctly he does have a predator 212.
between the lines... but I'm fairly certain about that.
Anywhoo
if it's not.. getting a flywheel made to fit your exact engine is a MUST!
Anything that is not a true clone (like predators) must be confirmed to work by the maker of the flywheel you buy.
True clones are identical to the Honda GX;
so if it's made for the GX(same size) you're good to go.
A predator is just similar, not identical (huge difference ;))
Logan County Ohio
Thanks guys, I was talking about a Predator, as I understand the taper is slightly different than the other clones. The ad I saw was either an ARC or Rasceng, it was adjustable too, pardon my spelling.
Thought maybe I could save a bunch of weight, but not with that shaft size. It was only $100.00, should have known, "If it seems too good to be true, it probably ain't".
porsche930dude
Upstate, NY
the output shaft is 5/8 vs. 3/4 that doesnt mean the flywheel side isnt the same. Call whoever is selling the flywheel they should know if itll work.
Logan County Ohio
This flywheel is an ARC adjustable, meaning it has a separate hub assembly. I wonder if the hubs won't interchange between their 6.5 and 3Hp? If so, one might end up with a smaller diameter flywheel on a 6.5. It might be hard to start but should spool up quick!
On would need to move the coil in to match the smaller flywheel but this shouldn't be a biggie.
Logan County Ohio
I just got the skinny from ARC, #6603 is a 5 3/4" flywheel for a GX200, THE STOCK DIAMETER is 6.625" and it weighs 2.85#.
The same flywheel for a PREDATOR is #6603-P
They list part # 5982 as the coil bracket needed to mount the coil using these flywheels.
So somebody already thought of it and made it easy for us! Thought I'd share this.
