modelengineer
Lord of the noise
Can you guess why it's named "Bleeding Ears"? The exhaust on this old Tecumseh 2-stroke rusted through so I welded up a bit of pipe I had lying around. Yes, I know the 90 degree bend is not good, but this has so little power anyway I don't think it makes much difference, it certainly hasn't quieted it down. IT'S LOUD!. Also bypassed the governor for a bit more speed!
Most of it was built in 1 week of the holidays and the finishing touches done in the first 2 weeks of school.
Office chair is very comfortable, but I placed the steering wheel on before the chair, so its a bit low but you can still turn to full lock.
25 degrees castor, 5 degrees king pin angle, and 0 degrees camber make it handle very well. Live axle with a manual belt clutch which worked flawlessly.
No brakes as yet, going to add a handbrake to do handbrake turns.
Top speed was around 35-40kph at an earsplitting 5000 RPM.
