Rockabilly87
Hi there!
Short info about me : I'm 26 , listen to 50s/60s rock (preferably from vinyl ) , i like generally V8/Engines/Mechanics. My current project has begun:
Available is a Tecumseh lawn mower engine with 3.5 hp to be converted to a horizontal mode. Next then are still a " good sounding " custom exhaust and some changes on gasification and sport air filter on the plan. I hope to find some help and pro’s here about 4 stroke. The old thread with the same engine i found here, too but have some questions.
Current status:
Motor was in a horrible external condition! So really first taken away all that crap roughly with the garden hose ;-) Next quickly built an engine stand from a wooden plate on a bucket . Air filter checked and discarded right away. Tank and air filter housing removed and drained the oil. Fogged everything roughly with WD40.
After I screwed the spark plug out , it was full of oil and crumbs . Cylinder head down , piston moves and everything shines as it should. But then oil drops out of the inlet valve and I toke the carburetor off and it drops out. Carburetor cleaned externally.
Then politely asked to a repair shop for a puller . After I looked at the camshaft closer I knowed that it’s a "ram pump” in there , as expected , it pushes the oil in a very simple manner through the inner camshaft to the upper bearing . The upper bearing is still a deeper hole that goes to the flywheel side in a channel to the main bearing .
Until now I have been thinking about a future lubrication with oil finger / oil slinger on the connecting rod bearings. Now i’m thinking about the tolerances of the camshaft bearing for eg (i don’t know the correct words, sorry). Are the tolerances for bearings smaller for this kind of lubrication than for an oil slinger construction? Do the tolerances allow an adequate lubrication in this engine?
Or should I install an external oil pump through to the camshaft bearings like in this thread?
Current status:
