3.5 hp Briggs lawnmower conversion
robbie
Osceola, Missouri
I thought I should move the discussion about my plans for the Briggs mower engine for my new minibike to the engine section.
Regarding the carburetor replacement, I was advised to use the carb off the 8 HP briggs if it was less than 20 mm, but I measured it at 23 mm.
I have a Honda carburetor I bought from ebay to put on a 5 hp Briggs horizontal shaft engine, but I haven't gotten to that project yet. I measured the inside diameter at 18 mm. Anybody have an opinion about putting an 18 mm carburetor on a 130 cc four stroke?
sideways
Unfinished projects king.
Perth, Western Australia
You could probably get away with the 8HP one. Honda one would be good.
130cc sounds a bit small, what is the first number in your engines model-type-code?
Thanks
Hayden
robbie
Osceola, Missouri
Sorry, I remembered it incorrectly. It's actually 148 cc. I have two of these. One mower smokes like crazy, and the other has a bent crankshaft. The smoky one says Model 81.
I've never been fond of the carburetor on the 8 hp Briggs engines. They're not bad, but certainly not the best thing that ever happened. I'm thinking the Honda will probably be better.
sideways
Yeah, I don't like 8HP carbs either, the Honda one would be ideal IMO.
What color smoke is it?
Thanks
Hayden
robbie
Osceola, Missouri
It's oil smoke. I think it has worn out rings. A friend gave us the mower last year after they converted their city yard to a wild, natural environment with native plants. It was low on oil when we got it. I fill it up and it smokes the oil off pretty quick. It's noticeably weaker than the other mower.
The other mower was given to us about 8 years ago by my in-laws. I used it for years to cut my yard in town, and it was always a good engine, although starting it required a specific choke-throttle adjustment ritual. It runs stronger than the smoky one, although it vibrates if you run it too fast because I hit the water meter cover in my yard and bent the crank shaft.
I always assumed that I would put the crank from the smoky one into the stronger one, but now that I've decided to grind down the crank to fit the clutch, maybe I won't have to.
robbie
Osceola, Missouri
Actually, I should say "burned up rings" rather than "worn out rings". After I saw how it ran, I assumed that it burned up from low oil.
robbie
Osceola, Missouri
Two updates on this thread.
I got the Honda GX160 carburetor for the Briggs 3.5 lawnmower engine. The original engine has the carburetor on the left, a long tube running under the blower shroud, and the intake valve on the right. I'm planning to ditch that in favor of an intake pipe no more than a few inches long, and mount the carburetor next to the exhaust pipe. I'm pretty sure that the poor starting characteristics of this engine are due to the long intake tube. I always wondered, if a giraffe eats too quickly he will cause himself to be overstuffed, because there will still be a lot of food on the way down at the moment he first feels full. I think the same thing happens to my lawnmower, because you have to choke it, then stop choking, then you can expect the mower to start as if choked when it's not, but then it will die, so you have to put the choke back on momentarily, etc. It sucks. I want to see if a short tube corrects this problem. I may have to cut a notch in the blower shroud, but it won't be any big deal. I'll make the pipe out of steel tube and a couple of pieces of plate steel for the end flanges.
The other update is that I checked the crankshaft runout on the non-smoky engine to see if it was really bent, or if the vibration was caused by a chunk missing from one blade or something. I turned the mower sideways and put a yardstick across the bottom and observed the bolt in the middle as I turned the blade. Instead of spinning in place, the center of the bolt travels in a circle about an inch in diameter. That's a pretty badly bent crankshaft. Obviously I won't be able to grind it back to a centered, straight shaft.
So, I'll have to revert to plan A. I'll take the crank out of the smokey engine and put it in the engine that runs well, and then file down the crankshaft to match my torque converter.
