22mm mikuni carb tuning help
umahunter
Well I got the governor removed and new carb installed on my subaru robin ex27 9 hp. thing I'm trying to figure is where to start. it starts up and runs with the choke lever pulled but the second I flip off the choke it dies. I know these have a idle and air jet screw just trying to figure where to start first figured I would ask before jumping in and finding out I should of done this instead of that first. it has in it a 125 main jet and 12.5 pilot jet as a starting point on the advice from seller since I only planned doing a carb and eventually exauhst to the engine thanks for any advice :thumbsup:
umahunter
pics
Here some pics :)
DirtyDamage
Westminster Colorado
On the back near the intake manifold there should be a screw underneath. That's your a/f mixture screw.
On the first picture the screw that is on that side is your idle speed.
May need to clean the carb again too. They're really sensitive.
umahunter
hmm
Ok I messed with it some it will only start with the choke once running I've got it to idle at 2500 anything lower and it sounds like crap and sound like its gonna sputter out . that seems really high to me for an idle I've checked the tach to make sure it's working right and it says I've programed it right
umahunter
Ok will do just seems odd since it's a new carb but maybe some dirt got in or something thanks for your help
anderkart
Surprise Arizona USA
Have you already confirmed if your intake adapter system is making a perfect seal or not?
(you'd just need to spray some carb cleaner all around it with the engine running, and if you detect this causes any change in rpm or the sound of the engine, that's confirming its leaking/sucking-air, and might just be your main problem here...)
Have you tried experimenting with different needle-clip positions?
There's lots of good info in these 2 links:
http://www.affordablegokarts.com/carburetor-tuning.php
http://www.affordablegokarts.com/Mikuni tuning manual.pdf
I also agree with DirtyDamage's posts:
You might have some dirt in your fuel tank that's already plugged up yer brand new carb. Cleaning out the fuel tank and Installing an in-line fuel filter would be a very good Idea, especially if you discover the jets/passage ways of your new carb are already plugged up with dirt... :thumbsup:
