22hp torque converter
ROLY239
Puerto Rico
deciding on purchasing a Lifan 22hp engine but i dont know any torque converter that can withstand 22hp. A few people have recommended the 40 series but I feel like it wont be able to handle that much power. Thanks in advance
I'm hoping for more than 22HP out of my 420cc engine and plan on using a knockoff 40 series.
Call Geoff at Vegascarts.com
I'm sure he'll have a good recommendation for you.
http://www.vegascarts.com/780-Performance-Clutch-1-Shaft-p/780r.htm
7-3/8" Heavy Duty Primary Drive Clutch (780R)
1" bore,
1/4" keyway.
For use with 1" or 1-3/16" - 1-1/4" width belt.
7.375" Diameter.
Rated to 20+ HP & 6000+RPM
Tuned specifically for the 420, 440 & 460 Clone engines and 4-stroke V-Twins in a golf cart application.
Yes it’s a 1inch crankshaft. What driven would I use with the 94c duster?
I guess the 90D driven unit that is listed below it in the link. The 90D has just under a 10" Diameter and comes in either a 3/4" or 1" bore. So you need a 3/4" or 1" jackshaft. It takes a 1-3/16" belt.
